QT5 generate with petalinux 2018.3 over HDMI
Hello all
Is somone knows if it's possible to run QT application on ZynqMP using acceleration from MALI GPU  to the Display HDMI and not to the DisplayPort  ?
I think the for the current release it need to run Xorg server on HDMI display but How to do that? Ideally I would use one plane of the IP Video mixer to surimpose my QT generted application as an overlay layer?
Tags (2)
HI @ericzerbib ,
You are right. I have moved it.
Is this page what you were looking for?
Florent
HI @ericzerbib ,
I believe the following design is doing GT over HDMI which is what you are looking ofr:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/126189670/Zynq+UltraScale+MPSoC+Base+TRD+2019.1+-+Design+Module+6
Hope that helps,
Florent
It's strange the detail document for Design Module 6 fro Base TRD 1029.1 are still under 2018.3 section, you should perhaps move them under
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/126320678/Zynq+UltraScale+MPSoC+Base+TRD+2019.1
HI @ericzerbib ,
Florent
1- Thanks to have moving the pages
2- Yes It's seams that the software choose automatically the output HDMI or DisplayPort I'm currently downloding the TRD Base and have a look how to use it under my application, Thanks
Hello
Is this base TRD runnable on ZC106 EVB
Hi @ericzerbib ,
No the TRD is targetting the ZCU102 but you can use it as reference for ZCU106
Florent
