Query on Characters 800x600 @72Hz VGA
Hello, I have a problem with vga 800x600 72hz. For example, between H and I characters, there are a few pixels. Can you help me fix the error? Thank you.
Re: Query on Characters 800x600 @72Hz VGA
Hi @taipham1996 ,
Do you have any update on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Hi @taipham1996 ,
Can you show a picture of what you get on the monitor?
Florent
Mentor
Mentor
Hi @taipham1996
Do you want to implement like this function to output font data ?
https://en.wikipedia.org/wiki/Sprite_(computer_graphics)
Best regards,
Hi @taipham1996 ,
Thanks and Regards,
Florent
