chenhai
Questions about FIR design for Image processing.
1. How to deal with the front and end pixel, when doing a 1-D x-filter(1,k) with FIR filter?
2. How to apply a 1-D y-filter(k,1) to the input (m,n) image or a time serialized (1, m*n) image?
3. When we are talking about the down/up sample the time serialized image, does it mean sampling in row form? How to sample the ”column“ form then?
4. What is the "transpose FIR filter"?
gszakacs
Professor
Professor
For your first two questions:
One approach is to essentially assume there is a "mirror" on each edge of the image and create pixels as necessary to fill the filter pipeline.  For example if you need 3 extra pixels at the beginning and end of a 10 pixel row, whre your original data is p1, p2, p3, ... p9, p10,  then you would run the filter on:
p3, p2, p1, p1, p2, p3, p4, p5, p6, p7, p8, p9, p10, p10, p9, p8
While the X filtering is simple in a rasterized image, Y filtering generally requires line buffers.  It also means you'll need to use multiplier based filters rather than distributed arithmetic, because the filter is working on a different column on each successive clock cycle.  The only other approach is to have a filter per column, which can require a lot of logic if the image size is large.
-- Gabor
chenhai
Thanks very much...
