jjf
Reading and writing to DRAM with Zynq-7000 VIP
I am using the vip, I write to DRAM with
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.write_data(32'h10000300, 32'hABCDEF01, 128);
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.read_data(32'h40000000,128,read_data,resp);
I am running the vdma, and I see it wants data at h10000300,  but I get unknowns.  What and I doing wrong
jjf
 sorry, I am using the write_mem and read mem commands.
So, the tb code is:
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.write_mem(32'hABCDEF01,, 32'h10000300, 128 );
tb.zynq_sys.base_zynq_i.processing_system7_0.inst.read_mem(32'h10000300, 128, resp);
I am trying to back door writing to DRAM.  Does DRAM need to me there in the simulation model?
jjf
To continue.  The S_AXI_HP0_RDATA is undefined.  I also tried with preloading the DDR (pre_load_mem)
watari
Hi @jjf
Would you share your bd as pdf or picture ?
Best regards,
jjf
I solved this with pre_mem_load
