Regarding the VTPG v7.0
I am referring to the VTPG v7.0 PG103, April05, 2017. At page 14, the AXI4_Lite control interface is described and the signals are tabulated.
1. There is a typo at the 2nd row of this table. The s_axi_CTRL_awread should be s_axi_CTRL_awready.
2. I don't see the the *_wstrb signal in this table. But the *_wstrb signal is depicted at page 9, fig 2-1.
Now if I refer to the Xilinx Video Beginner Series 4 Tutorial and run the simulation, then I see the Xilinx AXI VIP driving the *_wstrb.
My question is, is it necessary to drive the *_wstrb signal for configuring the VTPG?
@florentw
FPGA enthusiast!
All PMs will be ignored
Hi @dpaul24
[Florent] - This is fixed in the latest version of the doc (Video Test Pattern Generator v8.0 - PG103 December 17, 2019), Xilinx is not updating the previous versions of a doc.
[Florent] - No this is not required. This is coming from the fact that the TPG is a HLS based IP. When an AXI4 interface is implemented using HLS, all the signals will be implemented even the one which are optional. In the AXi4-Stream spec, the wstrb signal is an optional signal.
The test pattern generator uses the AXI4-Stream as defined in UG934, which is kind of the Xilinx spec for AXI4-Stream interfaces for Xilinx Video IPs. All the Xilinx Video IPs follow this guide to ensure inter-compatibility. The WSTRB is not used by any Xilinx video IPs. So you can leave it unconnected or connected all bit to 1.
Florent
Hi @dpaul24
Florent
