SDI core - Delay/latency from tx_ds1a/ds2a_in input to tx_txdata output
Is there a specificied latency from the input of the SDI core (tx_ds1a/ds2a_in) inputs to the output of 20-bit transceiver data?
Looking at the TX block diagram in PG071 (Figure 3-6), there are some registers documented, but there are other blocks such as the LN Insertion, CRC Generate/Insert and SDI Scrambler where I don't know what the latency through those blocks is.
Thank you!
Hi @dmtutd ,
The same latency should apply for all the 3 rates supported by the IP (SD/HD/3G-SDI). I will update the AR.
Florent
I forgot to add that I've found the documented latency in 3G_SDI mode per the AR below, but wasn't sure if that applied to SDI or HD-SDI mode as well.
https://www.xilinx.com/support/answers/70041.html
Hi @dmtutd ,
Florent
