SDI ref clock switch
in our new project we have to integrate an UHD-SDI receiver in a Kintex 7 - 160 device. I have to switch the clock for integer (1.000) order fractional (1.001) signals. How can I switch the QPLL automatical between 148.5MHz and 148.35MHz for the different clocks? I read the XAPP1249 and PG205 but I can't find anything about this.
Thank you for your help.
BR
martin sauer
Re: SDI ref clock switch
check these XAPP
http://www.xilinx.com/support/documentation/application_notes/xapp888_7Series_DynamicRecon.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp879.pdf
Thanks and Regards
Balkrishan
but the UHD-SDI core have to change the clock. In XAPP1249 figure 5 there is a signal called QPLLREFCLKSEL. Which module has to set this signal?
BR
martin sauer
Yes the cpllrefclksel and qpllrefclksel should be controlled.
In XAPP1249 this is controlled by an dip switch on the board.
Refer to kc705_uhdsdi_demo.v module in the XAPP1249 sources folder to get more details on how this is implemented.
Satish
my problem is, that in our design I have only the receiver and no dip-switch. I think the receiver should change these signals.
BR
martin sauer
I have a big problem that I don't understand the whole documentation about UHD-SDI core. There isn't a practical example, the demo system for kc705 board is impractical. I have to build a UDH-SDI receiver in the FPGA which should support HD-, 3G-, 12G-Standards with 148.5MHz and 148.5MHz/1.001. But there isn't a documentation which is useful. How can I switch between the two ref clocks?
BR
martin
Ok. But how does it works in a production system if I don't have any switches and only a receiver module?
BR
martin
