cor
SDK content for example Video DisplayPort 1.4 RX Subsystem IP
I have to use the Video DisplayPort 1.4 Rx Subsystem IP. To learn how to do this I have generated the example design for it.
I get a clear view of the hardware, which is very informative. Now I want to learn about the sofware controlling this hardware. But when launching the SDK it is empty. What do I need to do to see the code for this example?
watari
Professor
Professor
Hi @cor
Have you ever refered the following document at page 71 ~ ?
https://www.xilinx.com/support/documentation/ip_documentation/v_dp_rxss1/v1_0/pg300-v-dp-rxss1.pdf
Expesially, I suggest to refer flow 16 at page 73 and figure 5-15.
watari
Professor
Professor
Hi @cor
cor
Thanks! Didn't realize that the software had to be imported separately.
