SMPTE SD/HD/3G-SDI 3.0
Hello, I am using the Zinq Ultascale+ MPSoC and looking at the SMPTE SD/HD/3G-SDI 3.0 IP core for SDI Video.
https://www.xilinx.com/support/documentation/ip_documentation/v_smpte_sdi/v3_0/pg071-v-smpte-sdi.pdf
In Vivado I don't see this IP Core available what am I doing wrong?
I only see UHD-SDI Audio and UHD-SDI GT.
Joe
Hello @joe306 ,
PG071 describes the supported device.  From that table, I don’t think Zynq UltraScale + MOSoC is supportd.
PG289(SMPTE UHD-SDI TX Subsystem) and PG290(SMPTE UHD-SDI RX Subsystem) are supported instead.
Best regards,
kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
Hello @joe306 ,
Best regards,
kshimizu
Thank you very much. I will look into the UHD-SDI GT IP. Do you know if the IP can support 4 TX/RX streams or only TX/RX?
Thanks, Joe
