SMPTE UHD-SDI v1.0 IP and Quad Link 3G SDI
  Can SMPTE UHD-SDI v1.0 IP receive Quad Link 3G SDI input to combine into 1 video stream?
  If not, can I treat each Quad Link 3G SDI as independent and extract the video from it, and combine into 1 video outside of IP core?  Do I need a frame buffer for combining?
Neo
Hi wtneo@leica,
I do not think the UHD-SDI IP can combine streams. Thus you need to do it outside the core.
Yes a frame buffer might be an idea. It will really depends how the streams are (how the frame is distributed between the streams).
Hi wtneo@leica,
Hi wtneo@leica,
Do you have any updates on this? Was my reply enough for you?
Thanks and Regards,
The frame distribution (sub-image distribution) is described in SMPTE ST 425-5. But beware some cameras are non-compliant. They use the square subdivision scheme.
Simon
