SMPTE UHD-SDI v1.0 IP and Quad Link 3G SDI
  Can SMPTE UHD-SDI v1.0 IP receive Quad Link 3G SDI input to combine into 1 video stream?
  If not, can I treat each Quad Link 3G SDI as independent and extract the video from it, and combine into 1 video outside of IP core?  Do I need a frame buffer for combining?
Neo
Tags (2)
Hi wtneo@leica,
I do not think the UHD-SDI IP can combine streams. Thus you need to do it outside the core.
Yes a frame buffer might be an idea. It will really depends how the streams are (how the frame is distributed between the streams).
Florent
Hi wtneo@leica,
Florent
Hi wtneo@leica,
Do you have any updates on this? Was my reply enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
The frame distribution (sub-image distribution) is described in SMPTE ST 425-5. But beware some cameras are non-compliant. They use the square subdivision scheme.
Simon
