Setting the DDS Phase Increment from Zynq ARM CPU
I am trying to use the DDS Compiler IP Core (v6.0) to generate a sine wave, where I can set the frequency from within the ARM CPU. I am using a single channel sine output.
As far as I understand, to do this I need to send a single word packet to the configuration stream input of the dds core (containing the new phase increment value). What is the best way of writing from the CPU to this configuration stream? I am trying to use the AXI-Stream FIFO (v4.0) Core to convert from memory mapped data to stream data, but the documentation says that a minimum of 4 words can be transferred per packet. Is there some other way to transmit a single word packet from the cpu to an axi-stream interface, or would I have to create my own peripheral?
Ryan
Re: Setting the DDS Phase Increment from Zynq ARM CPU
I think the easiest solution would be to make an AXI GPIO and drive the tdata and tvalid signal with the GPIO signals. Then connect the AXI port to one of the general purpose AXI busses on the Zynq PL side.
