08-02-2020 11:09 PM
Should the HS signal in MIPI output by the camera be connected to 2.5V BANK or 1.8Vbank?
08-02-2020 11:45 PM
Hello @ackye
Camera/Sensor with MIPI interface should output HS/LP signals using the same lane.
Are you using UltraScale+ devices ?
-- If this is the case, you should HP IO pin with VCCO=1.2V
Or are you using 7-series devices ?
-- If yes, please follow suggestion from XAPP894. You need to implement a resistor network or using 3rd vendor PHY device. This doc suggest using LVDS 2.5V for HS signals.
Thanks & regards
Leo
