C-Ramesh
Simulating Block Design which involves AXI4 Processor interface
Sir
I want to view the Native video ( RGB24 ,HS,VS) in hdmi using ZCU106 board.
I want to simulate the video pattern generator output and view in Model sim
Work carried out
1) Made block design - simple and validated
2) created wrapper and tet bench file
3) simulated
Problem
No data output coming from Video pattern gen IP block.
Pls suggest
dpaul24
@C-Ramesh ,
How do you expect your design to design when do not connect the most basic thing such as the reset to the vid-out block?
The aresetn is unconnected.
Also do you see those two yellow lines in the waveform? It indicates that they are not driven.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
francocapraro12
Hi @C-Ramesh ,
Can you provide the testbench file to see it.
Also check if your testbench file is set as Top in the Simulation part. You can check a tutorial in the forum:
https://forums.xilinx.com/t5/Video-and-Audio/Video-Beginner-Series-4-Simulation-with-the-Xilinx-TPG-IP/td-p/855134
Best,
FC
C-Ramesh
Dear Paul
I have tied with reset and clock. Output of video out ( AXI4 -Stream to video out) is keep as open.
Now i am not using the AXI4 control interface.
I have wrote clock logic in top design wrapper .
I want to simulate this Block design of video test pattern
There is no improvement. Clk net and Reset to Logic is showing " U state"
Pls help me
Ramesh
francocapraro12
Hi @C-Ramesh ,
I recommend you to see the tutorial that i sent you.
In your design, you can reduce the complexity, deleting the cloking wizard and system reset.
After that, you can implement a "clock source" in you testbench code in this way ( This contain just a part of the testbench, please finish it):
module tb_full(
reg  s_axi_aclk_0=0;
reg reset=0;
...... // MORE reg that you need
block_design design_1_i
  integer i;
 initial
        begin
            for (i=0   ;i< 10; i=i+1)
            begin
             //THIS WILL GENERATE A 100MHZ CLOCK
            #5 s_axi_aclk_0= ~s_axi_aclk_0;
            end
        reset=1;
            for (i=0   ;i< 2800; i=i+1)
            begin
            end
  end
endmodule
Best,
FC
dpaul24
@C-Ramesh ,
In that case I would say that those signals are not being properly driven from the testbench.
Post your testbench (within code tags or as an attachment, do not just paste it here).
Note that if you do not tag me, it is very much possible that I will not read this thread in the future.
watari
Professor
Professor
Hi @C-Ramesh
Why don't you use Simulation IPs ?
I'm sure that you can build simulation environment by GUI.
- Simulation Clock generator
- Simulation Reset Generator
- AXI Verification IP
- AXI4-Stream Verification IP
- AXI Traffic Generator
Best regards,
C-Ramesh
Dear Experts
Two things are not Clear to me.
Reset , and clock managed by simulation block. Blog is not  much explaining the below details.
1) m_axis_video_ready
2) How to program the video test pattern register using VIP block?
I am going through the VIP AXI  document. Pls through some light on this area
Your suggestion helps  me to make the things
Ramesh
watari
Professor
Professor
Hi @C-Ramesh
Did you refer PG267 ?
https://www.xilinx.com/support/documentation/ip_documentation/axi_vip/v1_1/pg267-axi-vip.pdf
Also, I suggest you to refer xilinx-vip-api-2019.1.zip .
https://www.xilinx.com/products/intellectual-property/axi-vip.html#documentation
Would you try them ?
Hope this helps.
Best regards,
dpaul24
@C-Ramesh ,
Pls help me
From the sim waveform it seems the main problem is how you are driving the clock and rest signals. You think you are driving those signals correctly, and if it is so, they would show up in the waveform.
I asked you to post the testbench but you didn't. If you are doing everything correctly, why are you shying away?
If you want help from me, post your testbench  (and do not forget to tag me) where the DUT is instantiated and its ports are driven.
C-Ramesh
Sir
I have gone though AXI Verification IP v1.1LogiCORE IP & downloaded the xilinx-vip-api-2019.1.zip
As per PG 267, Document is explaining the test simulation with respect to Table 6-1:Simulation Sets for AXI VIP. - It related with system Verilog. I could not able to find the system Verilog files , Second There is no sample Design w.r.t to Table 6.1.
I am sending simple GPIO design with VIP.
Will you provide some sample system Verilog file to simulate the AXIO GPIO.?
Pls suggest. ( simple gpio - vip attached , validated)
C-Ramesh
Sir
As per pg267-axi-vip.pdf , opened the example project suggested
While simulation it is giving following error
attached with this mail ( elabrate.log)
Pls suggest
