Spartan 6 IP core Video image processing
Dear Friends!
Can anybody say which video image processing IP core will be usefull in conversion of ADC data of luma(Y I suppose) from pixels of infrared matrix array(FPA)?
It is necessary cause Im going to transfer "infrared video" to VLC player
Mentor
Mentor
Re: Spartan 6 IP core Video image processing
Hi @addi
Sorry. It was not enough information for you.
So, I mention them again.
1. timing diagram
You should design detector logic with Vout_EN.
I guess you design RTL code with state machine which detect or/and generate sync signals.
2. color space
I guess you want to get RGB data. However you only receive Y.
So you need to change color space with ex. ITU BT. 709 color space (parameter).
Hi @addi,
This paper seems to describe what you are looking for:
https://www.researchgate.net/publication/233864765_Processing_of_the_image_from_infrared_focal_plane_array_using_FPGA-based_system
Dear florentw!
Thank you for your link but my question is still staying
Because Ive got FPA with just analog output without contol or sync signals.
Analog video digitized by A/D converter and FPGA gets digital value of pixels (Luma) - 640x480 = 307200 14-bits values of pixels.
I need to transfer these data through W5300 to PC VCL Player.
But before do it I have to do conversion under 307200 14-bits values of pixels to be recognized by UDP LAN Video for VLC player.
I though that I can do from 307200 14-bits values of pixels video format using Xilinx IP cores.
Now I still searching the decision..
Mentor
Mentor
Hi @addi
It's strange. At least, the design requests sync signal or frame start signal.
If it doesn't have any control and sync signals, how do you synchronize Y data ?
Dear Watari!
Yes you are right, Ive got frame sync signal, I meant that I havent got hsync and vsync signal, only Vout_EN and VOUT
Mentor
Mentor
Hi @addi
You can generate vsync, hsync, data enable signals with signal detector from Vout_EN and VOUT.
Dear Watari!
Mayby  you have known does Xilinx have appropriate IP core to do this conversion?
Mentor
Mentor
Hi @addi
I don't know whether Xilinx already released like this IP or not.
However, it is easy to generate these signals by yourself.
ex. "hsync" signal is generated by inverted Vout_EN.
Dear Watari!
Thank you, now I starting understanding, but left one monent - how to generate from digitized analog voltage from FPA - Y', Cr, Cb ?
Mentor
Mentor
Hi @addi
Sorry. I can not understand what you want to do and explain detail.
Because of it doesn't satisfy to reply it to you.
Would you share me your environment  and explain it,  too ?
HI @addi,
What is the interface you are using to receive Y Cb Cr? Is it through SDI?
Thanks Friends!
Sorry maybe I wrong in explanation, I have got infrared Focal plane array, 14 A/D converter, and Spartan 6 and wiznet W5300
FPA gets on output just analog voltage
I though I can do digitalization, convertation to the video standart and futher transfer to VLC player as LAN stream by UDP
Please correct me
Mentor
Mentor
Hi @addi
As you mentioned before, the important points are Vpp spec. on ADC and the degitalized range of video data.
If you already considered them, I suggest the following flow.
1. Receive degitalized data from ADC with suitable IO buffer.
2. Implement matrix logic in FPGA and set the parameter. ex. ITU BT. 709 colorimetric. (color space) (from Y to RGB color space)
3. Some application, like VLC, encode video data and output it via Ethernet.
Dear Watari !
Thank you for your support
Yes I have done it 5V, 40 Mhz
About your steps, I will do this , but left one question - how to convert analog voltage of analog video signal to YCrCb?
I found Xilinx IP YCrCb to RGB color space converter which helps futher
Mentor
Mentor
Hi @addi
As you already mentioned before, you can only get luma as Y.
So, Cr and Cb are zero.
Dear Watari!
Thanks a lot, understand
Maybe you have known which timing diagram I should to use within conversion analog voltage of pixels to YCrCb?
Thanks in advance
Mentor
Mentor
Hi @addi
Yes.
BTW, if you understand or find the solution, could you close this issue ?
Also, if you have another question, would you post new thread ?
Dear Watari!
Rest one quedtion telated to topic about timing disgram, and also I dont known how to close issue in futher
Mentor
Mentor
Hi @addi
What kind of signals do you receive ?
Only Vout_EN and Vdata ?
If yes, as I already mentioned before, you should implement detector logic.
Dear Watari!
Yes.
Under detector logic you meant - "Implement matrix logic in FPGA and set the parameter. ex. ITU BT. 709 colorimetric. (color space) (from Y to RGB color space)"?
Mentor
Mentor
Hi @addi
1. timing diagram
2. color space
Thanks a lot!!
