State change failed (Zynq UltraScale+ MPSoC VCU TRD 2018.3 - HDMI Video Capture)
    When I use demo of  MPSoC VCU TRD 2018.3, some error happens. And I use computer's HDMI out to connecting the ZCU106 HDMI Rx port. Am I right?
STATE CHANGE FAILEDSTATE CHANGE FAILEDxmedia ctl logxmedia ctl log
Tags (3)
Hi @liufengwuhen ,
Make sure you are using the patch from AR#71798 as they might solve the issue you have.
The image.ub is download in rdf0428-zcu106-vcu-trd-2018-3\images\vcu_trd directory. Am I need to compile the petalinux again?
HI @liufengwuhen ,
Yes to apply the patch you will need to recompile the image.
HI @liufengwuhen ,
Do you have any updates on this? Were you able to test with the patch?
Thanks and Regards,
