Support Multiple DPHY On Single Board
Is it possible to have more that one MIPI DPHY on a single VCU118 board? We want to test two sensors at the same time.
Wei
Hi @summerweix
Check this FMC card from AVNET:
https://www.avnet.com/wps/portal/silica/products/new-products/npi/2018/avnet-multi-camera-fmc-module/
You might need to ensure that it will work with the VCU118 but it could be what you need
Florent
Hello @summerweix
# Let me add my two cents.
VCU118 has FMC HPC1 connector that is connected to HP IO (bank 66 and bank 67).
You can use these HP IO banks to implement your MIPI D-PHY RX IPs.
This UltraScale+ Virtex can implement MIPI D-PHY with line-rate up to 1500Mbps.
Thanks & regards
Leo
Hi @summerweix
Is your issue now resolved? If so, could you please mark the solution that helped most as an 'accepted solution'? If not, could you please update the community on your current status?
Aoife
