Supported Resolutions for the Display Port RX subsystem 2.1 for Kintex-7
Dear all,
Does the Display Port RX subsystem 2.1 for Kintex-7 (speed grade -2),
is able to support a single stream with 3200x1200 pixel frames at 120 fps?
Thanks in advance,
Andrea
Hi @andreac_avnet
As @florentw already mentioned before, DP Rx can have capability for "3200x1200 pixel frames at 120fps".
However, if you consider compatibility, I suggest to follow VESA CVT formula.
I guess, what you want to do is different, but I suggest it.
HI @andreac_avnet,
The Displayport RX subsystem should be able to support any resolution sent by a DP1.2 compliant source.
Basically, I can support resolutions which are in the DP1.2 bandwidth. You can check as follow:
The maximum lane rate for DP1.2 is 5.4 Gbps. As you can have up to 4 lanes, the maximum bandwidth is 21.6Gbps. As the data is 8b/10b encoded, the maximum data rate (or effective bandwidth) for DP1.2 is 17.28Gbps.
The data rate is computed as follow:
Total Horizontal Pixels * Total Vertical Lines * Refresh Rate * Component * Bits per component
Example with 3200*1200 assuming you are using reduced blanking in RGB (3 components), 8 bits per component:
Total Horizontal Pixels = 3280 (3200 active + 80 blanking)
Total Vertical Lines = 1271 (1200 active + 71 blanking)
Data rate = 3280 * 1271 * 120 * 3 * 8 = 12.006Gbps which is under the DP1.2 maximum bandwidth.
Thus the IP should be able to receive this resolution.
Hope that helps,
Hi @andreac_avnet
