home1
Sysgen 11.2 does not generate netlist while Xilinx 10.1 and 11.2 are installed together.
When I tried to generate the netlist for the same design only 11.2 installed computer, there was no problem at all.
But when I try to do same thing with computer both versions are installed, it gives an error:
Errors occurred during netlist generation.
Error using ==> xlCompileGenerateMdl at 187
Error reported by S-function 'sysgen' in '.../Fast Fourier Transform 7.0 1':
When I remove the fft block, it still gives an error for another thing such as constant.
I uninstalled 10.1 DSP tools but it doesn't help. I checked system variables, their path seems ok.
Is there any solution other than uninstall everything and reinstall 11.2?
benchan
Please check if the XILINX environment variable points to ISE 11.2. Also, %XILINX%/bin/nt and %XILINX%/lib/nt should appear at the beginning of PATH (you may have ISE 10.1 paths appear before ISE 11.2 paths on the PATH variable).
- Ben
