Anonymous
Not applicable
System Generator blocks are "Initializing" every time during simulation
Here is some background:
Windows 7 Pro 64-bit, ISE version 13.1 64-bit, System Generator version 13.1, Matlab R2010bSP1 64-bit
Every time I simulate the design, all the block s must initialize before the simulation can begin.  This happens whether I simulate once or ten times in a row ( one after the other).  I have read other posts like "System Generator works very slow. Why?" on this forum but none of the recommended fixes have resolved my problem.  Initializing all the blocks in the design slows my simulation time since it has to do this every time it simulates.  How can I resolve this?
This is not the expected behaviour.  I recommend opening a Webcase on this issue.
Chris
Versal ACAP: AI Engines | Embedded SW Support
