Systems Generator on Windows Vista Business
i want to know if there is any possibility to run Systems Generator on a Windows vista business machine ?
I tried to do that and got severe problems concerning the MINGW-installation.
I have seen that the problems with MINGW and Vista in general are already solved, so is there a workthrough to change the MINGW-installation of systems generator manually so that the system will run ??
Thanks for your answer
D
Unfortunately System Generator is not supported on Windows Vista and there are known issues, if installed, that will prevent it from running.  I am not aware of any ways to workaround these.
The best way to log an official request for Vista support (or any OS for that matter) is to submit a webcase through Xilinx Support.  Otherwise there is only anecdotal data which generally isn't very persuassive.
