jia149751
TPG+VDMA+HDMI ON ZC706 Board
vivado2014.4
    I download the prj from https://github.com/analogdevicesinc/hdl
    set for zc706 board, now HDMI is OK on monitor, but I add TPG and set VDMA write enable,
    but HDMI is not normal show tartan bars pattern in monitor, monitor show is not like my image, actually show like RGB stripe,
    can you help me where is not correct?
    Thank you very much!!!
watari
Hi @jia149751
I recommend to change AXI4Stream clock frequency from 100MHz to at least over 133.333MHz. (Need to change some parameter, too) But I recommend to change ASI4Stream clock to 150MHz.
It's AXI4Stream band width issue, when the target resolution is 1920x1080.
Would you consider and change it ?
jia149751
florentw
HI @jia149751,
How did you programmed the VDMA? It looks like a configuration issue
jia149751
VDMA SET:
 //add VDMA ctrl by jxd zzcx 20190110
    Xil_Out32(VDMA_BASEADDR + 0x30, 0x4); //reset   S2MM VDMA Control Register
    Xil_Out32(VDMA_BASEADDR + 0x30, 0x8); //genlock
    Xil_Out32(VDMA_BASEADDR + 0xAC,   0x08000000);//S2MM Start Addresses
    Xil_Out32(VDMA_BASEADDR + 0xAC+4, 0x0A000000);
    Xil_Out32(VDMA_BASEADDR + 0xAC+8, 0x0D000000);
    Xil_Out32(VDMA_BASEADDR + 0xA4, (640*4));//S2MM Horizontal Size
    Xil_Out32(VDMA_BASEADDR + 0xA8, (640*4));//S2MM Frame Delay and Stride
    Xil_Out32(VDMA_BASEADDR + 0x30, 0x3);//S2MM VDMA Control Register
    Xil_Out32(VDMA_BASEADDR + 0xA0, 480);//S2MM Vertical Size  start an S2M
    Xil_DCacheFlush();
 Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_DMA_CTRL),
     0x00000003); // enable circular mode
 //modify VDMA frame address by jxd zzcx 20190110
    Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_START_1),
            0x08000000); // start address
    Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_START_2),
            0x0A000000); // start address
    Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_START_3),
            0x0D000000); // start address
 Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_FRMDLY_STRIDE),
     (horizontalActiveTime*4)); // h offset
 Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_H_SIZE),
     (horizontalActiveTime*4)); // h size
 Xil_Out32((VDMA_BASEADDR + AXI_VDMA_REG_V_SIZE),
     verticalActiveTime); // v size
watari
Hi @jia149751
Could you shre the followings ?
- Pitcure to output color bar, gray scale and RGB ramp image (gradation)
- Timing report file
jia149751
sorry,I don't understand very well about your means.
your means:
TPG output set: color bars and share the timing report file, Am I right?
florentw
Hi @jia149751,
I do not unserstand why you program your HSIZE as 640*4? You are using 8 bit per component and 3 component per pixel. So you should have 3 byte per pixel, thus your HSIZE might be 640*3 unless I am missing something?
florentw
HI @jia149751,
Thanks and Regards,
jia149751
ADI HDMI_TX use VDAMdata[55:32] and [23:0],so I change TPG output data [23:0] to VDMAdata={8'h0,TPG[23:0],8'h0,TPG[23:0]},
so set pixel*4, now 640x480,monitor display is OK, but 1920x1080,monitor display likes below:
from 640x480 to 1600x900 are OK, why 1920x1080 is wrong, can anyone tell me somthing,thanks!
watari
Hi @jia149751
Would you tell me the following questions ?
1) What clock frequency do you use in a) 640x480, b) 1600x900 and c) 1920x1080 ?
2) What HSIZE do you program in a) 640x480, b) 1600x900 and c) 1920x1080 ?
jia149751
TPG:100MHZ
VDMA:100MHZ
HDMI: a) 640x480 :25MHZ   b) 1600x900:108MHZ   c) 1920x1080: 148.5MHZ
(horizontalActiveTime*4);
used the HDMI core expects 2 pixel at once, how TPG generates 2 pixels as well ?
watari
Hi @jia149751
florentw
Hi @jia149751 ,
Do you have any updates on this? Did you make any progress? Is your issue solved?
Thanks and Regards,
jia149751
TPG:148.5MHZ
VDMA:148.5MHZ
Problem is solved, Thanks every one for answer to me!
