kuroro20
TPG control color depth
I don't know if i missed something, is there a way to control the TPG color depth dynamically when the TPG is on generator mode ?
The only option i see is maximum color depth ,but if is the max, i should be able to generate less, no ?
Thx
florentw
HI @kuroro20
Well... the answer is yes and no.
Main answer is no, you cannot really change this setting in the TPG.
But when you configure the TPG to do max 10-bit, you set the AXI interface width. And if you add to transmit 8-bits per component data on a 10-bits per component bus, then you the data would be aligned on the MSB (as per UG934
And nothing defines that the padding bit (ex. bit 0 and 1) have to be 0. Thus they can be the value they would have been for 10-bits data.
So if you just ignore the bit you do not need then this is like sending another bpc configuration.
Florent
florentw
HI @kuroro20
Florent
kuroro20
Okay thank you
