di9876
Transmit HD-SDI over fiber optic using an SFP module
In my research I'm want to try this project:
using 2 EVB KCU105, FMC Card of HD-SDI, and Fiber-optic using in SFP module,
the connection from HD-SDI camera to the EVB (kcu105) with FMC card looks like something that possible,
but the transmission on fiber optic from let's say 2 cameras, is possible?
attaching a block scheme of the idea, maybe it will clarify my explanations Capture.PNG
Tags (2)
florentw
HI @di9876
Yes I believe this is doable. What you will need between the connectivity IPs (SDI and SFP and between SFP and HDMI) will be an IP (Intellectual Property) which can convert SDI to Internet Protocol (IP).
You might want to contact our partner Macnica which has an IP for this: https://macnicatech.com/intellectual-property/.
Florent
