UG1209 prebuilt image not working with supported monitor
Hello there,
  I'm trying to get the prebuilt image of example 2 (tricube) from the design files of UG1209 (v2018.2) working on zcu102 eval board revision 1.0.  The tricube application runs fine but the monitor cannot detect any signal.  Searching around the forum, I found that there is a list of supported monitors according to AR#68671.  It happens I have a DELL P2414Hb around so I tried with it again.  However, the monitor still can't detect any signal.
  The Xorg.0.log shows unable to find connected outputs.  Since I'm using a supported monitor and a prebuild image, I don't think it is a compatibility issue.   Could there be any configuration that I need to do for Xorg to get this work?  Attached is the Xorg.0.log and dmesg.txt.  Thank you for any help or suggestions.
Li
Xorg.0.log sections
[ 40.571] (II) ARMSOC(0): Got CRTC: 0 (id: 36)
[ 40.590] (II) ARMSOC(0): Output DP-1 has no monitor section
[ 40.609] (II) ARMSOC(0): EDID for output DP-1
[ 40.609] (II) ARMSOC(0): Output DP-1 disconnected
[ 40.609] (WW) ARMSOC(0): No outputs definitely connected, trying again...
[ 40.609] (WW) ARMSOC(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
Hi @lizhang86
What kind of cable do you use ? Use DisplayPort cable ?
Accordning to log files, it seems that it failed "reading EDID".
In this case, you should use DisplayPort Cable to connect your LCD monitor via DP or use an active adapter to connect your LCD monitor via HDMI...
Best regards,
Hi @lizhang86
Best regards,
Hi @watari
Thank you. I was using a Displayport to DVI cable. I will order a dp to dp cable and give it a try.
Li
    Tried the design with the DP to DP cable, everything works fine.  Thanks for all the help.
Li
HI @lizhang86,
As everything is working for you now, could you kindly mark @watari's reply as accepted solution to close the topic (click on "Accept as solution" button below the reply while logged in)?
Thanks and Regards,
Florent
