sebo
Voyager
Voyager
UHD-SDI Example design - ZCU102 Version
Hello @ajaykumargurrala,
A question related to this post: UHD-SDI Example design - ZCU102 Version
What hardware do you use for the SDI on this board ? a FMC?
Sebastien.
--Sebastien
ajaykumargurrala
Dear Sebastian,
My purpose of migrating the design was to use it with SDI SFP transceiver. So I have targeted it to one of the SFPs on board. You can use any FMC that supports FPGA transceiver based SDI.
Thanks and Regards,
Ajay Kumar G
ajaykumargurrala
Dear Sebastian,
Thanks and Regards,
Ajay Kumar G
sebo
Voyager
Voyager
Thanks @ajaykumargurrala!
Sébastien
--Sebastien
