V5sx95t support in system generator 10.1.03
I am using System Generator 10.1 and upgrade it to 10.1.03 .
When i am synthesis my design with device V5sx95T it shows me error
ERROR:TclTasksC - ERROR:TclTasksC:project_028 - project set : Unknown property
value "xc5vsx95t"
Type [project properties] for more information.
ERROR: An error occurred when creating the ISE project.
Failed to execute command "project set device xc5vsx95t".
ERROR:TclTasksC:project_030 - project set: Cannot set "Device=xc5vsx95t"
please help in resolving this problem
thanks
I recommend that you open up ISE and see if that part is availble in ISE.
If it is, you problaby need to regenerate the device cache for SysGen.
Chris
Versal ACAP: AI Engines | Embedded SW Support
