jeremy@easii-ic
VCU H264/H265 gop-mode
Hi guys,
The following Gstreamer pipeline using "Low-Delay P" GOP mode is working fine. However, If i set it to "Basic" or "Low delay B" (which are supported by the VCU), I get an OpenMax error. Any Idea ?
rtpbin name=rtpbin v4l2src io-mode=4 device=/dev/video1 ! videoconvert ! video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 !  omxh264enc num-slices=4 prefetch-buffer=true gop-length=30 periodicity-idr=120 b-frames=0 control-rate=2 target-bitrate=10000 cpb-size=200 initial-delay=100 gop-mode=3 gdr-mode=vertical filler-data=false min-qp=10 max-qp=51 ! h264parse ! rtph264pay config-interval=10 pt=96 ! rtpbin.send_rtp_sink_0 rtpbin.send_rtp_src_0 ! udpsink host=239.255.0.1 port=50000 auto-multicast=true async=false
--> OK !
gst-launch-1.0 rtpbin name=rtpbin v4l2src io-mode=4 device=/dev/video1 ! videoconvert ! video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 !  omxh264enc num-slices=4 prefetch-buffer=true gop-length=30 periodicity-idr=120 b-frames=0 control-rate=2 target-bitrate=10000 cpb-size=200 initial-delay=100 gop-mode=0 gdr-mode=vertical filler-data=false min-qp=10 max-qp=51 ! h264parse ! rtph264pay config-interval=10 pt=96 ! rtpbin.send_rtp_sink_0 rtpbin.send_rtp_src_0 ! udpsink host=239.255.0.1 port=50000 auto-multicast=true async=false
--> Failure :
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0: Could not initialize supporting library.
Additional debug info:
../../../../git/gst-libs/gst/video/gstvideoencoder.c(1627): gst_video_encoder_change_state (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:
Failed to open encoder
Setting pipeline to NULL ...
Freeing pipeline ...
jeremy@easii-ic
Also would you add the following option to investigate route cause ?
gst-launch-1.0 --gst-debug-level=5 <....>
Thank you for the advice ! I've set the debug level to 5 as you recommended, and redirected the gstreamer output to a log file. The log is pretty clear :
0:00:00.450310084  2748   0x5597771400 ERROR            omxvideoenc gstomxvideoenc.c:778:set_zynqultrascaleplus_props:<omxh265enc-omxh265enc0> gdr-mode mode only can be set if gop-mode=low-delay-p
I've removed the gdr-mode property and now everything works. Thanks !
watari
Hi jeremy@easii-ic
What version are you useing ? 2019.2 or 2019.1 or 2018.3 or other ?
Best regards,
Best regards,
jeremy@easii-ic
@watari wrote:
Hi jeremy@easii-ic
What version do you use ? 2019.2 or 2019.1 or 2018.3 or other ?
Best regards,
2019.1 sir !
watari
Hi jeremy@easii-ic
Would you add the following between omx264enc and h264parse ?
! video/x-h264, alignment=au
Best regards,
jeremy@easii-ic
