MarcGV
VCU block diagram
I want to compress video data from a SDI-device. I figured out that I could use the VCU on my evaluation kit (ZCU106) but I'm really struggling with making a block design for this. I've tried to take a look at the trd but when I try to open the block design there are no connections made. Any idea how I can fix this or where I can find information about making this block diagram.
kind regards,
Marc
watari
Hi @MarcGV
I guess you are facing two kind of issue.
1) launch tcl script on wrong directory
> couldn't read file "designs/zcu106_trd/bd.tcl": no such file or directory
According to log file, you launch tcl script on wrong directory.
So, would you change current directory to <extract directory>/pl before launch tcl script ?
2) path length issue. (Maximum length is  260byte on Windows.)
I'm not sure. But you might be facing path length issue.
Because you launch this script file on Windows.
So, I recommend to fix this issue as below.
a) Modify maximum path length issue.
You can fix it to modify relevant parameter by registry editor.
b) Change  instance name as short as possible.
You can change instance name as short as possible on tcl script.
c) Change OS from Windows to Linux.
There is NOT like this limitation on Linux OS.
Best regards,
watari
Hi @MarcGV
Would you share log message on the console ?
Best regards,
MarcGV
Hi @watari,
This is the log message
regards
watari
Hi @MarcGV
Best regards,
MarcGV
Hi @watari
I changed the directory to something shorter and I tried another .tcl file.
Now the only error I get is this (refer to attachment)
I've checked the directory and the file should be there.
kind regards,
watari
Hi @MarcGV
># add_files -norecurse ./srcs/hdl/compact_gt_ctrl.v
>ERROR: [Vivado 12-172] File or Directory './srcs/hdl/compact_gt_ctrl.v' does not exist
>update_compile_order -fileset sources_1
As I mentioned before, you launched tcl script at wrong directory.
Would you change current directory to proper directory or change this file name path on "add_files" command ?
Best regards,
