joseer
Voyager
Voyager
VCU decode -> encode pipeline error - Driver bug detected
I need to post-process a previously encoded video file (using VCU, working with the 2018.3 tools version), for that I'm doing the next:
video file in -> decode -> process raw video -> encode back -> video file out
The gstreamer comand line:
gst-launch-1.0 filesrc location="input.ts" --gst-debug-level=2 ! tsdemux ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! v4l2video1convert capture-io-mode=4 output-io-mode=4 disable_passthrough=1 !  omxh264enc ! queue max-size-bytes=-1 ! h264parse ! mpegtsmux ! filesink location="output.ts"
The errors are:
0:00:00.103577456  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103693768  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103906720  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103943460  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
Any ideas why I'm getting this errors?
Tags (2)
joseer
Voyager
Voyager
Jus a quick update,
Using a USB3 memory I was able to get a video file decoded and encoded back again, not sure if this wil work with all video files but it seems to work better like this...
watari
Professor
Professor
Hi @joseer
Where do I get plugin's source code of "v4l2video1convert" ?
If it is inhouse gstreamer's plugin, make sure the capability of it on source and sink side.
If other, make sure an identity of input.ts.
Best regards,
joseer
Voyager
Voyager
Hi @watari , thanks for your answer.
The v4l2video1convert plugin is generated by the mem2mem driver   framework as a response to the hardware  definition in the device tree. I did check the capabilities and everything looks ok.
I made some tests and in order to debug this better I simplified the pipeline and tried only to decode the file but the pipeline gets stuck:
Pipeline:
gst-launch-1.0 filesrc location="input.ts" --gst-debug-level=2 ! tsdemux ! h264parse ! queue ! omxh264dec ! queue ! video/x-raw, width=1280, height=1024, format=NV16 ! filesink location="output.yuv"
 And it gets stuck here:
Setting pipeline to PAUSED ...
0:00:00.064188882  2436   0x7f98002360 WARN                 basesrc gstbasesrc.c:3480:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
Redistribute latency...
0:00:00.255551476  2436   0x7f98004c50 WARN                GST_PADS gstpad.c:4109:gst_pad_peer_query:<omxh264dec-omxh264dec0:src> could not send sticky events
0:00:00.255689397  2436   0x7f98004c50 WARN            videodecoder gstvideodecoder.c:3797:gst_video_decoder_negotiate_pool:<omxh264dec-omxh264dec0> Subclass failed to decide allocation
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
The generated file is big (> 1GB), could it be related to space allocation issue?
Any ideas?
watari
Professor
Professor
Hi @joseer
Make sure information of input.ts by the following commands.
$ ffprobe input.ts
$ ffmpeg -i input.ts
If you find color format as not NV16 (ex. NV12), change the capability from format=NV16 to format=<correct format>.
Also, I suggest you to add the following option on queue.
max-size-bytes=0
And, if you store the file by filesink on slow speed storage (like SD card, USB flash memory and USB 2.0 storage), I recommend to change it to USB 3.0 storage, too.
Best regards,
joseer
Voyager
Voyager
Hi @watari ,
Yes, the color formats are correct in NV16, I ran the next command to change them:
v4l2-ctl --device /dev/video0 --set-fmt-video=width=1280,height=1024,pixelformat=NV16
But I think you are right the issue might be bandwidth related, as I'm saving the file in a sd card, I'll check what are you suggesting and I'll get back.
florentw
HI @joseer
Do you have any update on this? Did you check if it was coming from the fact that you were using the SD card as memory?
Florent
joseer
Voyager
Voyager
Sorry, I had to move on with other pojects tasks and this gets a bit delayed but still need to solve it. Yes, first thing I'm planning to test a USB memory instead and see if that still happening, I'll post the result.
joseer
Voyager
Voyager
Jus a quick update,
