VCU example design
Hello!
According to our FAE it should be possible to generate an example design for the VCU now. I tried this in both 2017.3 and 2017.4 but the option to open example design is greyed out.
Also, he asked me to open a service request on the matter (he was out travelling), but i could not do this. Could someone take a look on my account and see if it can be made possible, i think we are supposed to be able to do it.
Regards, Thomas
Hi @tharvid,
The example design for the VCU, called VCU TRDs, are still in limited access. Please ask your FAE to contact technical support to get you access to them.
Hi @tharvid,
