laplace12
VDMA is not Mapped
I am using evaluation board ZCU104. I am using the PYNQ baseline and I am trying to add in another VDMA. I followed an example of the existing vdma in the block diagram but only enable the read channel. Eveything is connected up in the block diagram but address editor still shows that my vdma is unconnected. I tried to use auto address assigment with no success. Include is the snapshot of my address editor. Help is appreciated.
Tags (2)
samk
Hi @laplace12,
In your picture it still shows auto-assign as green when you select this do you get any warnings/messages in the tcl console?
What version of the tools are you using? 2019.2?
Can you share your connection from the Processor to the VDMA? Based on what I see below, it looks like it may not be connected properly.
If you run validate design, do you get errors other than the VDMA being unassigned?
Xilinx Video Design Hub
samk
Hi @laplace12,
