nemesmarcell
VDMA - setup no output signals (hsync, vsync)
I have a Vivado module design which is attached as a pdf but I have attached a picture of the most relevant part of the design.
As I have observed using an ILU module, the output signals hsync and vsync are set to constant value 0 so those are not generated correctly.
Based on the manual of the used VGA expansion module, we have set 50MHz as the clock for the video system.
I have implemented the initialization of the VDMA module as follows:
This section is called like this:
status = run_frame_buffer(XPAR_AXIVDMA_0_DEVICE_ID, HRES, VRES);
if (status != 0) {
xil_printf("Failed to run framebuffer, status: 0x%X\r\n", status);
return XST_FAILURE;
Here can be seen the setup for each module:
Can anyone help me why the VGA output signals are set to constant 0 value?
Thank you for the help!
florentw
Hi @nemesmarcell
You might want to check the register values of the VDMA to see if you have any error. You might want to refer to my Video Series 25: Debugging issues on the AXI VDMA IP
florentw
HI @nemesmarcell
You might want to read my Video Beginner Series 8: Debugging the AXI4-Stream to Video Out IP
Checking with an ILA the overflow, underflow and stratus output of the AXI4-Stream to Video out will probably help
nemesmarcell
According to my analysis the VDMA doesn't provide any outputs.
Do you have any idea what could be wrong in this case? Please take a look at the attached pdf and the implementation.
The goal would be to send 640*480 RGB VGA image from the memory.
watari
Hi @nemesmarcell
I suggest you to set the parameter as VGA video timing (640x480@60Hz) on VTC.
Also, I suggest you to refer @florentw 's Video Beginner Series 8.
florentw
Hi @nemesmarcell
