VDMA with TPG
    When I make an example with VDMA 、TPG、VTC and Video Out IP core。my system block is like this。just flow
when I use SDK run the VDMA example (xaxivdma_example_intr.c),during I config VDMA core with the function int XAxiVdma_SetFrmStore(XAxiVdma *InstancePtr, u8 FrmStoreNum, u16 Direction);(in xaxivdma.h)
XAxiVdma_Channel *Channel;
if(FrmStoreNum > InstancePtr->MaxNumFrames) {
return XST_FAILURE;
Channel = XAxiVdma_GetChannel(InstancePtr, Direction); // ERROR
if (!Channel) {
return XST_FAILURE;
if(XAxiVdma_ChannelIsRunning(Channel)) {
xdbg_printf(XDBG_DEBUG_ERROR, "Cannot set frame store..."
"channel is running\r\n");
return XST_FAILURE;
if (!(Channel->DbgFeatureFlags & XAXIVDMA_ENABLE_DBG_FRMSTORE_REG)) {
"Frame Store Register is disabled\n\r");
return XST_NO_FEATURE;
XAxiVdma_WriteReg(Channel->ChanBase, XAXIVDMA_FRMSTORE_OFFSET,
FrmStoreNum & XAXIVDMA_FRMSTORE_MASK);
Channel->NumFrames = FrmStoreNum;
XAxiVdma_ChannelInit(Channel);
return XST_SUCCESS;
I get Channel with 0x19, mean  NULL.  Now how can I fix the problom?
HI @huyongwei ,
Do you have any updates on this? Were you able to solve your issue?
Thanks and Regards,
Hi @huyongwei ,
Can you share your full project?
You might want to refer to some video series I wrote related to the VDMA, this might help:
Video Series 24: Using the AXI VDMA in Triple Buffer Mode
Video Series 25: Debugging issues on the AXI VDMA IP
Video Series 26: Examples of advanced uses of the AXI VDMA IP
HI @huyongwei ,
Thanks and Regards,
Hello, @Moderator
Thanks for your reply, But my issue is'not be solved,Maybe the file xaxivdma_example_intr.c (API)can't be used in a baremetal system? Now I use Xli_IO.h for may VDMA's configuration. then everythings is going on well.
Thanks and Regards.
HI @huyongwei ,
xaxivdma_example_intr.c is for a baremetal application but you need to make sure the VDMA is properly connected (you have the interrupts connected properly in you HW).
@florentw I meet the same question too. This is my question discription.
https://forums.xilinx.com/t5/Video/ZCU102-VDMA-test-failed/m-p/977233#M25453
I have also encountered this problem. Is there a hardware project corresponding to vdma_example_intr.c?
