hitpmpm@163.com
VDMA write channel config failed
hello everyone
I am doing the motion detection project on zedboard .   firstly, I want to capture the video by the ov5640 ,then pass it to hdmi to display, but when I use the vdma to transfer data from ddr to pl ,it met problem in SDK as follows thanks!
 my block design is as follows
besides,my  code is as follow
main.c
#include "sys_intr.h"
#include "xaxivdma.h"
#include "xaxivdma_i.h"
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
//#define VTC_BASEADDR XPAR_MIZ702_VTG_VGA_0_BASEADDR
#define DDR_BASEADDR        0x00100000
#define UART_BASEADDR       0xe0001000
#define VDMA_BASEADDR       XPAR_AXI_VDMA_0_BASEADDR
#define H_STRIDE            1280
#define H_ACTIVE            1280
#define V_ACTIVE            720
#define pi					3.14159265358
#define COUNTS_PER_SECOND	(XPAR_CPU_CORTEXA9_CORE_CLOCK_FREQ_HZ)/64
#define VIDEO_LENGTH  (H_STRIDE*V_ACTIVE)
#define VIDEO_BASEADDR0 DDR_BASEADDR + 0x2000000
#define VIDEO_BASEADDR1 DDR_BASEADDR + 0x3000000
#define VIDEO_BASEADDR2 DDR_BASEADDR + 0x4000000
u32 *BufferPtr[3];
unsigned int srcBuffer = 0x00000000;//(XPAR_PS7_DDR_0_S_AXI_BASEADDR  + 0x1000000);
int run_triple_frame_buffer(XAxiVdma* InstancePtr, int DeviceId, int hsize,
		int vsize, int buf_base_addr, int number_frame_count,
		int enable_frm_cnt_intr);
int main(void)
	init_platform();
	u32 Status;
	Miz702_EMIO_init();
	ov5640_init_rgb();
	XAxiVdma InstancePtr;
	xil_printf("Starting the first VDMA \n\r");
	Status = run_triple_frame_buffer(&InstancePtr, 0, 1280, 720,
							srcBuffer, 2, 0);
		if (Status != XST_SUCCESS) {
			xil_printf("Transfer of frames failed with error = %d\r\n",Status);
			return XST_FAILURE;
		} else {
			xil_printf("Transfer of frames started \r\n");
	print("TEST PASS\r\n");
	//VDMA configurateAXI VDMA0
	/*****************往DDR写数据设置**********************/
	/*Xil_Out32((VDMA_BASEADDR + 0x030), 0x00000003);// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x0AC), VIDEO_BASEADDR0);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B0), VIDEO_BASEADDR1);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B4), VIDEO_BASEADDR2);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0A8), (H_STRIDE*4));		// h offset (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A4), (H_ACTIVE*4));		// h size (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A0), V_ACTIVE);			// v size (480)
	/*****************从DDR读数据设置**********************/
	/*Xil_Out32((VDMA_BASEADDR + 0x000), 0x00000003); 		// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x05c), VIDEO_BASEADDR0); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x060), VIDEO_BASEADDR1); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x064), VIDEO_BASEADDR2); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x058), (H_STRIDE*4)); 		// h offset (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x054), (H_ACTIVE*4)); 		// h size (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x050), V_ACTIVE); 			// v size (480)
	while (1) ;
		return XST_SUCCESS;
	   // cleanup_platform();
	    //return 0;
vdma_api.c
#define DEBUG_MODE		0
/******************** Include files **********************************/
#include "xparameters.h"
#include "xil_exception.h"
/******************** Data structure Declarations *****************************/
typedef struct vdma_handle
	/* The device ID of the VDMA */
	unsigned int device_id;
	/* The state variable to keep track if the initialization is done*/
	unsigned int init_done;
	/** The XAxiVdma driver instance data. */
	XAxiVdma* InstancePtr;
	/* The XAxiVdma_DmaSetup structure contains all the necessary information to
	 * start a frame write or read. */
	XAxiVdma_DmaSetup ReadCfg;
	XAxiVdma_DmaSetup WriteCfg;
	/* Horizontal size of frame */
	unsigned int hsize;
	/* Vertical size of frame */
	unsigned int vsize;
	/* Buffer address from where read and write will be done by VDMA */
	unsigned int buffer_address;
	/* Flag to tell VDMA to interrupt on frame completion*/
	unsigned int enable_frm_cnt_intr;
	/* The counter to tell VDMA on how many frames the interrupt should happen*/
	unsigned int number_of_frame_count;
}vdma_handle;
/******************** Constant Definitions **********************************/
 * Device related constants. These need to defined as per the HW system.
vdma_handle vdma_context[XPAR_XAXIVDMA_NUM_INSTANCES];
static unsigned int context_init=0;
/******************* Function Prototypes ************************************/
static int ReadSetup(vdma_handle *vdma_context);
static int WriteSetup(vdma_handle *vdma_context);
static int StartTransfer(XAxiVdma *InstancePtr);
* run_triple_frame_buffer API
* This API is the interface between application and other API. When application will call
* this API with right argument, This API will call rest of the API to configure the read
* and write path of VDMA,based on ID. After that it will start both the read and write path
* of VDMA
* @param	InstancePtr is the handle to XAxiVdma data structure.
* @param	DeviceId is the device ID of current VDMA
* @param	hsize is the horizontal size of the frame. It will be in Pixels.
* 		The actual size of frame will be calculated by multiplying this
* 		with tdata width.
* @param 	vsize is the Vertical size of the frame.
* @param	buf_base_addr is the buffer address where frames will be written
*		and read by VDMA.
* @param 	number_frame_count specifies after how many frames the interrupt
*		should come.
* @param 	enable_frm_cnt_intr is for enabling frame count interrupt
*		when set to 1.
* @return
*		- XST_SUCCESS if example finishes successfully
*		- XST_FAILURE if example fails.
	int Status,i;
	XAxiVdma_Config *Config;
	XAxiVdma_FrameCounter FrameCfgPtr;
	/* This is one time initialization of state machine context.
	 * In first call it will be done for all VDMA instances in the system.
	if(context_init==0) {
		for(i=0; i < XPAR_XAXIVDMA_NUM_INSTANCES; i++) {
			vdma_context[i].InstancePtr = NULL;
			vdma_context[i].device_id = -1;
			vdma_context[i].hsize = 0;
			vdma_context[i].vsize = 0;
			vdma_context[i].init_done = 0;
			vdma_context[i].buffer_address = 0;
			vdma_context[i].enable_frm_cnt_intr = 0;
			vdma_context[i].number_of_frame_count = 0;
		context_init = 1;
	/* The below initialization will happen for each VDMA. The API argument
	 * will be stored in internal data structure
	/* The information of the XAxiVdma_Config comes from hardware build.
	 * The user IP should pass this information to the AXI DMA core.
	Config = XAxiVdma_LookupConfig(DeviceId);
	if (!Config) {
		xil_printf("No video DMA found for ID %d\r\n",DeviceId );
		return XST_FAILURE;
	if(vdma_context[DeviceId].init_done ==0) {
		vdma_context[DeviceId].InstancePtr = InstancePtr;
		/* Initialize DMA engine */
		Status = XAxiVdma_CfgInitialize(vdma_context[DeviceId].InstancePtr,
						Config, Config->BaseAddress);
			xil_printf("Configuration Initialization failed %d\r\n",
					Status);
			return XST_FAILURE;
		vdma_context[DeviceId].init_done = 1;
	vdma_context[DeviceId].device_id = DeviceId;
	vdma_context[DeviceId].vsize = vsize;
	vdma_context[DeviceId].buffer_address = buf_base_addr;
	vdma_context[DeviceId].enable_frm_cnt_intr = enable_frm_cnt_intr;
	vdma_context[DeviceId].number_of_frame_count = number_frame_count;
	vdma_context[DeviceId].hsize = hsize * (Config->Mm2SStreamWidth>>3);
	/* Setup the write channel */
	Status = WriteSetup(&vdma_context[DeviceId]);
		xil_printf("Write channel setup failed %d\r\n", Status);
		if(Status == XST_VDMA_MISMATCH_ERROR)
			xil_printf("DMA Mismatch Error\r\n");
		return XST_FAILURE;
	else
		xil_printf("Write channel setup sucess %d\r\n", Status);
	/* Setup the read channel */
	Status = ReadSetup(&vdma_context[DeviceId]);
		xil_printf("Read channel setup failed %d\r\n", Status);
		return XST_FAILURE;
	/* The frame counter interrupt is enabled, setting VDMA for same */
	if(vdma_context[DeviceId].enable_frm_cnt_intr) {
		FrameCfgPtr.ReadDelayTimerCount = 1;
		FrameCfgPtr.ReadFrameCount = number_frame_count;
		FrameCfgPtr.WriteDelayTimerCount = 1;
		FrameCfgPtr.WriteFrameCount = number_frame_count;
		XAxiVdma_SetFrameCounter(vdma_context[DeviceId].InstancePtr,&FrameCfgPtr);
		/* Enable DMA read and write channel interrupts. The configuration for interrupt
		 * controller will be done by application	 */
		XAxiVdma_IntrEnable(vdma_context[DeviceId].InstancePtr,
				XAXIVDMA_IXR_ERROR_MASK |
				XAXIVDMA_IXR_FRMCNT_MASK,XAXIVDMA_WRITE);
				XAXIVDMA_IXR_FRMCNT_MASK,XAXIVDMA_READ);
	} else	{
					XAXIVDMA_IXR_ERROR_MASK,XAXIVDMA_WRITE);
					XAXIVDMA_IXR_ERROR_MASK ,XAXIVDMA_READ);
	/* Start the DMA engine to transfer */
	Status = StartTransfer(vdma_context[DeviceId].InstancePtr);
		return XST_FAILURE;
#if DEBUG_MODE
	xil_printf("Code is in Debug mode, Make sure that buffer addresses are at valid memory \r\n");
	xil_printf("In triple mode, there has to be six consecutive buffers for Debug mode \r\n");
		u32 pixels,j,Addr = vdma_context[DeviceId].buffer_address;
		u8 *dst,*src;
		u32 total_pixel = vdma_context[DeviceId].WriteCfg.Stride * vdma_context[DeviceId].vsize;
		src=(unsigned char *)Addr;
		dst = (unsigned char *)Addr + (total_pixel * vdma_context->InstancePtr->MaxNumFrames);
		for(j=0;j<vdma_context->InstancePtr->MaxNumFrames;j++) {
			for(pixels=0;pixels<total_pixel;pixels++) {
				if(src[pixels] != dst[pixels]) {
					xil_printf("VDMA transfer failed: src=0x%x, DST=0x%x\r\n",
							src[pixels],dst[pixels]);
					exit(-1);
			src=src + total_pixel;
			dst = dst + total_pixel;
	xil_printf("VDMA transfer is happening and checked for 3 frames \r\n");
#endif
	return XST_SUCCESS;
* This function sets up the read channel
* @param	vdma_context is the context pointer to the VDMA engine.
* @return	XST_SUCCESS if the setup is successful, XST_FAILURE otherwise.
* @note		None.
	int Index;
	u32 Addr;
	int Status;
	vdma_context->ReadCfg.VertSizeInput = vdma_context->vsize;
	vdma_context->ReadCfg.HoriSizeInput = vdma_context->hsize;
	vdma_context->ReadCfg.Stride = vdma_context->hsize;
	vdma_context->ReadCfg.FrameDelay = 1;  /* This example does not test frame delay */
	vdma_context->ReadCfg.EnableCircularBuf = 1;
	vdma_context->ReadCfg.EnableSync = 1;  /* Gen-Lock */
	vdma_context->ReadCfg.PointNum = 0;
	vdma_context->ReadCfg.EnableFrameCounter = 0; /* Endless transfers */
	vdma_context->ReadCfg.FixedFrameStoreAddr = 0; /* We are not doing parking */
	/* Configure the VDMA is per fixed configuration, This configuration is being used by majority
	 * of customer. Expert users can play around with this if they have different configurations */
	Status = XAxiVdma_DmaConfig(vdma_context->InstancePtr, XAXIVDMA_READ, &vdma_context->ReadCfg);
		xil_printf("Read channel config failed %d\r\n", Status);
		return XST_FAILURE;
	/* Initialize buffer addresses
	 * These addresses are physical addresses
	Addr = vdma_context->buffer_address;
	for(Index = 0; Index < vdma_context->InstancePtr->MaxNumFrames; Index++) {
		vdma_context->ReadCfg.FrameStoreStartAddr[Index] = Addr;
		/* Initializing the buffer in case of Debug mode */
#if DEBUG_MODE
			u32 i;
			u8 *src;
			u32 total_pixel = vdma_context->ReadCfg.Stride * vdma_context->vsize;
			xil_printf("Read Buffer %d address: 0x%x \r\n",Index,Addr);
			for(i=0;i<total_pixel;i++)
				src[i] = i & 0xFF;
#endif
		Addr +=  vdma_context->hsize * vdma_context->vsize;
	/* Set the buffer addresses for transfer in the DMA engine
	 * The buffer addresses are physical addresses
	Status = XAxiVdma_DmaSetBufferAddr(vdma_context->InstancePtr, XAXIVDMA_READ,
			vdma_context->ReadCfg.FrameStoreStartAddr);
		xil_printf(
			"Read channel set buffer address failed %d\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
* This function sets up the write channel
* @param	dma_context is the context pointer to the VDMA engine..
* @note		None.
	int Index;
	u32 Addr;
	int Status;
	vdma_context->WriteCfg.VertSizeInput = vdma_context->vsize;
	vdma_context->WriteCfg.HoriSizeInput = vdma_context->hsize;
	vdma_context->WriteCfg.Stride = vdma_context->hsize;
	vdma_context->WriteCfg.FrameDelay = 0;  /* This example does not test frame delay */
	vdma_context->WriteCfg.EnableCircularBuf = 1;
	vdma_context->WriteCfg.EnableSync = 1;  /*  Gen-Lock */
	vdma_context->WriteCfg.PointNum = 0;
	vdma_context->WriteCfg.EnableFrameCounter = 0; /* Endless transfers */
	vdma_context->WriteCfg.FixedFrameStoreAddr = 0; /* We are not doing parking */
	 * is being used by majority of customers. Expert users can play around
	 * with this if they have different configurations
	Status = XAxiVdma_DmaConfig(vdma_context->InstancePtr, XAXIVDMA_WRITE, &vdma_context->WriteCfg);
		xil_printf(
			"Write channel config failed %d\r\n", Status);
		return Status;
	 * Use physical addresses
	/* If Debug mode is enabled write frame is shifted 3 Frames
	 * store ahead to compare read and write frames
#if DEBUG_MODE
	Addr = Addr + vdma_context->InstancePtr->MaxNumFrames * \
			(vdma_context->WriteCfg.Stride * vdma_context->vsize);
#endif
		vdma_context->WriteCfg.FrameStoreStartAddr[Index] = Addr;
#if DEBUG_MODE
		xil_printf("Write Buffer %d address: 0x%x \r\n",Index,Addr);
#endif
		Addr += (vdma_context->hsize * vdma_context->vsize);
	/* Set the buffer addresses for transfer in the DMA engine */
			XAXIVDMA_WRITE,
			vdma_context->WriteCfg.FrameStoreStartAddr);
		xil_printf("Write channel set buffer address failed %d\r\n",
				Status);
		return XST_FAILURE;
	/* Clear data buffer
#if DEBUG_MODE
	memset((void *)vdma_context->buffer_address, 0,
			vdma_context->ReadCfg.Stride * vdma_context->ReadCfg.VertSizeInput * vdma_context->InstancePtr->MaxNumFrames);
#endif
	return XST_SUCCESS;
* This function starts the DMA transfers. Since the DMA engine is operating
* in circular buffer mode, video frames will be transferred continuously.
* @param	InstancePtr points to the DMA engine instance
* @return
*		- XST_SUCCESS if both read and write start successfully
*		- XST_FAILURE if one or both directions cannot be started
* @note		None.
	int Status;
	/* Start the write channel of VDMA */
	Status = XAxiVdma_DmaStart(InstancePtr, XAXIVDMA_WRITE);
		xil_printf("Start Write transfer failed %d\r\n", Status);
		return XST_FAILURE;
	/* Start the Read channel of VDMA */
	Status = XAxiVdma_DmaStart(InstancePtr, XAXIVDMA_READ);
		xil_printf("Start read transfer failed %d\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
mkorobkov
As i see in your code sometimes you use 1280*720 and sometimes you have settings for 640*480.
Could you set one resolution not both or this is a part of your design with different resolutions?
Sorry for my English.
florentw
HI hitpmpm@163.com,
Do you still have issue on this?
Dir the reply from @mkorobkov helped you? If yes could you mark it as accepted solution (button accept as solution below the reply when logged in) to close the topic?
Thanks and regards,
nomi_070
Hello hitpmpm@163.com
Did you solve your problem. I am having the same problem could you please guide me how you solved it.
florentw
HI @nomi_070 ,
Please create a new topic if you have an issue, you have more chance of getting helped
Also you might want to have a look at my Video Series 24: Using the AXI VDMA in Triple Buffer Mode and Video Series 25: Debugging issues on the AXI VDMA IP
