skos
VPSS bypass vdma
We are planning a system that incorporates a a VPSS core, in full-fledged mode since we need some of the features only available in full-fledged mode. Our problem is that in our system when we want the output video to be the same size as the input,  the VDMA will consume too much memory bandwidth even though it is not really necessary.
Can the VDMA be somehow bypassed or disabled for this case?
florentw
Hi @skos
Looking a the VPSS driver, it seems that the AXI VDMA will always be enabled even if scaling ratio is 1:
https://github.com/Xilinx/embeddedsw/blob/f975a0ea90930587ab55e4d920a31950bd373fa8/XilinxProcessorIPLib/drivers/vprocss/src/xvprocss_router.c#L223
You could try to edit the driver to change the internal routing of the VPSS to avoid going to the AXI VDMA. However, this is not supported by Xilinx (thus not recommended). So you would need to do you own characterization to make sure it can work or not
Florent
florentw
Hi @skos
Florent
