VPSS example design without DMA
Is there any example design for KCU105/ZCU102 (preferably ) which uses VPSS (Video Processing subsystem) without DMA / frame buffer enabled?
I refered to https://www.xilinx.com/support/documentation/application_notes/xapp1291-video-subsystem.pdf example design
I understand that DMA is required for supporting Interlaced video. Currently I am working with Progressive video inputs only.
I created the design in kCU105 with HDMI in & out using VPSS and the design is working with DMA enabled in VPSS. As our design has critical DDR4 bandwidth requirement, we want to avoid DDR bandwidth usage for VPSS. So, I disabled the DMA inside VPSS and commented the "XVprocSs_SetFrameBufBaseaddr" in sdk.
With Regards,
Hariprasad Bhat
Hi @hariprasadb,
In the current version of vivado (2018.3) you can generate the VPSS example design for a specific configuration. For example you should be able to generate it in chroma ressampler only. This shouldn't use the DMA.
To generate the example design, refer to PG231 chapter 5.
Hi @hariprasadb
What resolution and frame rate do you support ?
It depends on this answer wheter you can do it or not.
Hi @watari,
Currently I am targetting for full hd 1080P @60Hz wuth HDMI RX and TX subsystems.
HDMI RX SS(FHD 60HZ) -> VPSS (RGB to YCBCR) -> HDMI TX SS (FHD 60HZ).
Once this is done, we are planning 720@60Hz, 1080P@30Hz as well.
With Regards,
Hariprasad Bhat
Hi @hariprasadb
It's wasy way to use a lerge FIFO as line buffer or AXI4Stream IP (Video in to AXI4Stream and AXI4Stream to Video out).
Would you consider them ?
Hi @hariprasadb,
Hi @hariprasadb ,
Thanks and Regards,
