gladson
VPSS scaler - parse_of failed and failed to get axi lite clock
I am working on a Zynq MPSoC 5ev custom board.
Our project pipeline is:
TPG -> VPSS (scaler) -> Framebuffer write -> DDR -> Framebuffer read -> VPSS (scaler) -> arinc tx
Both the VPSS scaler used, are giving issue and pipeline is broken. I am using /gpu/drm/xlnx/xlnx-scaler driver.
I have attached system-user dtsi below.
LOG:
root@DEV_KIT:~# dmesg | grep tpg
[ 3.743290] xilinx-tpg a00d0000.v_tpg: device found, version 0.000
[ 3.749469] xilinx-video amba_pl@0:vcap_out: Entity type for entity a00d0000.v_tpg was not initialized!
root@DEV_KIT:~# dmesg | grep scaler
[ 2.902968] xlnx,scaler-bridge a0040000.v_proc_ss: failed to get axi lite clk -517
[ 2.907590] xlnx,scaler-bridge a0040000.v_proc_ss: parse_of failed
[ 2.913778] xlnx,scaler-bridge a0080000.v_proc_ss: failed to get axi lite clk -517
[ 2.921250] xlnx,scaler-bridge a0080000.v_proc_ss: parse_of failed
[ 3.447088] xlnx,scaler-bridge a0040000.v_proc_ss: xlnx drm scaler experimental driver probed
[ 3.455771] xlnx,scaler-bridge a0080000.v_proc_ss: xlnx drm scaler experimental driver probed
root@DEV_KIT:~# media-ctl -p
Failed to enumerate /dev/media0 (-2)
root@DEV_KIT:~# dmesg | grep frmbuf
[ 2.861503] xilinx-frmbuf a0030000.v_frmbuf_rd: failed to get ap_clk (-517)
[ 2.866672] xilinx-frmbuf a00c0000.v_frmbuf_wr: failed to get ap_clk (-517)
[ 3.414849] xilinx-frmbuf a0030000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV
[ 3.422289] xilinx-frmbuf a0030000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 3.430931] xilinx-frmbuf a00c0000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[ 3.438375] xilinx-frmbuf a00c0000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
xlnx-pl-disp amba_pl@0:arinc-pl-disp_0: failed to request dma channel
xilinx-video amba_pl@0:vcap_scaler: /amba_pl@0/vcap_scaler/ports/port@0 initialization failed
xilinx-video amba_pl@0:vcap_scaler: DMA initialization failed
zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
phy phy-fd400000.zynqmp_phy.0: Looking up phy-supply property in node /amba/zynqmp_phy@fd400000/lane0 failed
phy phy-fd400000.zynqmp_phy.1: Looking up phy-supply property in node /amba/zynqmp_phy@fd400000/lane1 failed
phy phy-fd400000.zynqmp_phy.2: Looking up phy-supply property in node /amba/zynqmp_phy@fd400000/lane2 failed
phy phy-fd400000.zynqmp_phy.3: Looking up phy-supply property in node /amba/zynqmp_phy@fd400000/lane3 failed
ahci-ceva fd0c0000.ahci: Looking up target-supply property in node /amba/ahci@fd0c0000 failed
zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
gladson
Hi @furball
Please add this in system-user.dtsi
&scaler_1 {
    compatible = "xlnx,v-vpss-scaler-2.2";
Considering your boot log I came to know that you are loading DRM driver for input path VPSS.
furball
Hi @gladson ,
Did you solve the problem?
I'm facing similar failure.
[ 3.075636] xilinx-video amba:vcap_csi: device registered
[ 3.075709] xilinx-video amba_pl@0:vcap_scaler_1: No Video DMA channel found
[ 3.075727] xilinx-video amba_pl@0:vcap_scaler_1: /amba_pl@0/vcap_scaler_1/ports/port@0 initialization failed
[ 3.075742] xilinx-video amba_pl@0:vcap_scaler_1: DMA initialization failed
gladson
Hi @furball
Can you please share pl.dtsi, system-user.dtsi and also boot log?
I have found the solution for my problem. It may not be same solution in your case. So I would like to get little more info on the same and I will give you my point of view.
With Regards,
Gladson
Abhishekkumar
Hi @gladson,
I am facing similar issue. If you are able to solve the issue could you please update the solution?
Thanks and Regards
Abhishek
nathanx
The problem is likely due to device tree or your setting in your BD design, so, a quick way to verify the issue is to compare Xilinx demo with yours.
Xilinx VCU TRD has working v4l2 capture pipelines, e.g., HDMI RX -> Video Scaler -> Frame buffer write. Generate the bd design and also get the device tree, compare them with yours. Hope it helps.
furball
Hi @gladson ,
Thanks for your quick reply, Here's my pl.dtsi, system-user.dtsi and also boot log.
Could you also share yours?
gladson
Hi @furball
&scaler_1 {
furball
Hi @gladson ,
After adding the node in system-user.dtsi, I could successfully find a media device. Thanks for your help.
ls /dev | grep "media"
media0
But, though I can see "VPSS Scaler Probe Successful" in boot log, I still got those errors :
"xilinx-video amba_pl@0:vcap_scaler_1: No Video DMA channel found"
"xilinx-video amba_pl@0:vcap_scaler_1: /amba_pl@0/vcap_scaler_1/ports/port@0 initialization failed"
"xilinx-video amba_pl@0:vcap_scaler_1: DMA initialization failed"
not sure if it matters. Did you have the same problem?
[ 3.074537] xilinx-video amba:vcap_csi: device registered
[ 3.074610] xilinx-video amba_pl@0:vcap_scaler_1: No Video DMA channel found
[ 3.074628] xilinx-video amba_pl@0:vcap_scaler_1: /amba_pl@0/vcap_scaler_1/ports/port@0 initialization failed
[ 3.074643] xilinx-video amba_pl@0:vcap_scaler_1: DMA initialization failed
[ 3.075159] xilinx-csi2rxss 80000000.mipi_csi2_rx_subsystem: Xilinx CSI2 Rx Subsystem device found!
[ 3.075180] xilinx-video amba:vcap_csi: Entity type for entity 80000000.mipi_csi2_rx_subsystem was not initialized!
[ 3.076355] xilinx-video amba:vcap_csi: Entity type for entity 80040000.v_proc_ss was not initialized!
[ 3.076374] xilinx-vpss-scaler 80040000.v_proc_ss: Num Hori Taps 6
[ 3.076385] xilinx-vpss-scaler 80040000.v_proc_ss: Num Vert Taps 6
[ 3.076396] xilinx-vpss-scaler 80040000.v_proc_ss: VPSS Scaler Probe Successful
gladson
Hi @furball
Please do stream video and check whether you are getting output. If not, please debug using ILA( Integrated Logic Analyser).
With Regards,
Gladson
furball
Ok I’ll try that. Thanks
