Video Beginner Series 4 testbench question
Hello@florentw ,
In the test-bench it is seen that that a wait time of 200ns is inserted before the required bits in the  TPG_CONTROL_REG is set.
Why is this so?
    //Wait for the reset to be released
    wait (aresetn == 1'b1);
    #200ns
    //Set TPG output size
    master_agent.AXI4LITE_WRITE_BURST(TPG_ACTIVE_H_REG,0,height,resp);
    master_agent.AXI4LITE_WRITE_BURST(TPG_ACTIVE_W_REG,0,width,resp);
    //Set TPG output background ID
    master_agent.AXI4LITE_WRITE_BURST(TPG_BG_PATTERN_ID_REG,0,9,resp);
    #200ns
    // Start the TPG in free-running mode
    master_agent.AXI4LITE_WRITE_BURST(TPG_CONTROL_REG,0,8'h81,resp);
Why can't we immediately start the axi4lite transaction for the TPG_CONTROL_REG after the TPG_BG_PATTERN_ID_REG is set to value 9?
FPGA enthusiast!
All PMs will be ignored
HI @dpaul24
There is no specific reason. It was just for me to have a nicer waveform to idenfify when I was doing each transaction.
But if you think about it, in a real system, the processor will probably take some time between transactions so to simulate closer to reality it would probably require time between each transaction.
Florent
HI @dpaul24
Florent
