tgharbi2020
Video Framebuffer Write - handling interrupt in linux app
I'm implementing a video framebuffer write IP in my design.
I want to define a callback function to handle its interrput in my linux app.
The given example design is a baremetal application.
There is another one based on V4L2 driver, but it's just an abstract : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842236/Video+Framebuffer+Write
Can you advice me the simplest way to do this?
watari
Professor
Professor
Hi @tgharbi2020
I guess this URL is useful for you, if you describe userland application for Video Framebuffer Write.
Would you refer it ?
https://www.xilinx.com/support/answers/62363.html
Best regards,
florentw
Hi @tgharbi2020
The wiki page you mention is maybe just an abstract but it seems to contain everything you need.
Florent
tgharbi2020
Hi @florentw
I cannot find :
- anywhere "to_frmbuf_dma_chan(xdev)" function
- the address returned by "vb2_dma_contig_plane_dma_addr" function is not used in the abstract.
- for zynq (and arm arch), when I compile the code, the asm/current.h file is not found (but for arm64 arch it exists)
That's why I'm confused.
florentw
@tgharbi2020 wrote:
Hi @florentw
I cannot find :
I assume this is the users responsibility to define this function. The code provided is just a template
Use the functions which are using xilinx_xdma_v4l2_config as reference.
I guess it is there in case you need it
You probably need to adapt.
Again this is only a template. You need to create you own code based on this
Florent
samk
Hi @tgharbi2020,
Is everything clear for you on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
tgharbi2020
Hi @samk
No. I created my code based on the given abstract but I cannot compile the dmaengine based project on SDK. I get recursive errors of missing files or errors under include/linux and include /asm even I included linux kernel sources path (the one generated by petalinux: petalinux/2018.3/myProject/build/tmp/work-shared/plnx-zynq7/kernel-source/include/).
I correct some of them but still have anothers. The last ones are:
include/asm-generic/bitops/fls64.h:34:2: error: #error BITS_PER_LONG not 32 or 64
include/asm-generic/bitops/sched.h:28:2: error: #error BITS_PER_LONG not defined #error BITS_PER_LONG not defined
include/linux/rcupdate.h:213:2: error: #error "Unknown RCU implementation specified to kernel configuration"
/include/linux/cpumask.h:168:37: error: "and" may not appear in macro parameter list
