Video Mixer not displaying solid background color
While implementing the video mixer(v3.0) on PYNQ-Z1 board at vivado 2018.3, the solid background color is not displayed on the monitor after disabling the master layer. I have already reviewed the video mixer page guide(PG243) and forum link.
I have here included the picture of debug status of video mixer and SDK code of video mixer implementation. I have also implemented upon the Zybo Z7-10 board, but not seen background color either.Terminal Debug Message.png
I apologize for late reply. Thank you for providing the link. I reviewed the link you had provided but was not working.
Now, I have found the solution myself. It was having problem to set solid background color, because I gave direct resolution value for the output stream from the video mixer IP.
When I added the two programmable VTC IPs, in hardware design, for detection and generation of video timing signal. Then I set the output resolution value, in video mixer IP, according to detected incoming video resolution, then it worked.
Now I can see the background color when I disable the master layer. This problem is solved.
Hi @Nikhil_Thapa
Have you also reviewed the video mixer tutorial on this? https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Video-Series-32-Visualizing-the-Video-Mixer-example-design-using/ba-p/1026338
If you believe it is a bug, can you provide a test case that I can run?
Aoife
