Video On-Screen Display (OSD) IP Vivado 2018.3
I have a problem with Layer 0 and background in VOSD IP Vivado 2018.3
I have 2 Layer input, and control configuration registers by SDK.
When I enabled only Layer 0 I see just some lines of Layer 0 and the other lines are background.
When I enabled only Layer 1 I see the entire frame.
Layer 1 comes from VDMA, while Layer 0 come VideoIn 2 Axis.
Layer 0 has global alpha, and Layer 1 has controllable alpha.
First figure show Layer 0 with problem, both Layer 0/1 with alpha Layer 1 fixed to max value, and both Layer 0/1 with alpha Layer 1 fixed to middle value.
What kind of problems are there?
Re: Video On-Screen Display (OSD) IP Vivado 2018.3
Hi @partieri
Note that the OSD IP is a discontinued IP. Xilinx will not provided any support for this IP. The recommendation is to use the Video Mixer
With that said I will still give you a guidance (which will be the only one from me but you might get more from the community). It might be that your stream from layer 0 is not fast enough. I would add an ILA to see if you have enough data in
Hi @partieri
Is possible to make overlay without axis streaming video?
Are there some ip for overlay that doesn't work with axis streaming video?
Hi @partieri
All the xilinx Video IPs are using AXI4-Stream.
Hi @partieri
Do you have any update in this topic? Is everything clear for you?
Thanks and Regards,
