partieri
Video On-Screen Display (OSD) IP Vivado 2018.3
I have a problem with Layer 0 and background in VOSD IP Vivado 2018.3
I have 2 Layer input, and control configuration registers by SDK.
When I enabled only Layer 0 I see just some lines of Layer 0 and the other lines are background.
When I enabled only Layer 1 I see the entire frame.
Layer 1 comes from VDMA, while Layer 0 come VideoIn 2 Axis.
Layer 0 has global alpha, and Layer 1 has controllable alpha.
First figure show Layer 0 with problem, both Layer 0/1 with alpha Layer 1 fixed to max value, and both Layer 0/1 with alpha Layer 1 fixed to middle value.
What kind of problems are there?
florentw
Hi @partieri
Note that the OSD IP is a discontinued IP. Xilinx will not provided any support for this IP. The recommendation is to use the Video Mixer
With that said I will still give you a guidance (which will be the only one from me but you might get more from the community). It might be that your stream from layer 0 is not fast enough. I would add an ILA to see if you have enough data in
Florent
florentw
Hi @partieri
Florent
partieri
Is possible to make overlay without axis streaming video?
Are there some ip for overlay that doesn't work with axis streaming video?
florentw
Hi @partieri
All the xilinx Video IPs are using AXI4-Stream.
Florent
florentw
Hi @partieri
Do you have any update in this topic? Is everything clear for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
