Video Processing Subsystem v2.0 single pixel input mapping
  I would like to use Video Processing Subsystem v2.0 for Chroma resampling from 4:2:2 to 4:4:4.
  Input is single pixel per clk, 10bit per component.
  On page 11 of PG231, there are info on how to map color components to TDATA vector for 2 pixel per clock.  However, there is no info on how to map 1 pixel per clk color components to TDATA.
  Pls provide info.
Neo
Hi wtneo@leica,
Please see UG934.
Table 1-4 includes the single pixel mapping that you are looking for.
2018-12-10 07_40_15-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
-Sam
Xilinx Video Design Hub
Hi wtneo@leica,
Please see UG934.
-Sam
