Video on screen display(OSD) ip licence
Hello everyone
Now I can't use the IP Video on screen display(OSD). I think it's caused by the licence issue.
How could I apply the licence for this ip?
Thank you very much!
HI @ceelgao,
The OSD IP is discontinued. You might want to use the Video Mixer instead.
Florent
HI @ceelgao,
Florent
Hi @ceelgao,
Do you have any updates on this? Did you decided to move to the Video Mixer?
Florent
