c.gannamani@gmail.com
Video phy controller example design
Hi Team,
I generated video phy controller IP core for HDMI TX configuration. The IP core got synthesized but I am unable to open IP example design (attached the image in which it is disabled).
Please provide the solution.
Thank you
Krishnachaitanya
Tags (2)
florentw
HI c.gannamani@gmail.com
For all versions before 2018.3, the Test Pattern Generator requires a license that you can generate for free from your licensing account.
Just search for the test pattern generator in the Evaluation and No Charge Cores and generate the license.
Or use a more recent vivado version
Florent
Hi, Waiting for your reply
florentw
It is not that you cannot open the example design for the Video phy, it is just that there is no example design for the Video Phy because the video phy cannot be used a standalone IP. It can only be used with the HDMI Subsystem IP or Displayport Subsystem IP.
If you want an example design you need to open from the HDMI Subsystem IP.
Florent
I want to use it with the HDMI TX Subsystem IP only.
I generated HDMI TX SUBSYSTEM then opened the example  design, it throws Video TPG Subsystem licence error.
Is there a way to open an example design and without Video TPG Subsystem module?
watari
Professor
Professor
Hi c.gannamani@gmail.com
Refer the following URL, even if it is described DP.
https://www.xilinx.com/support/answers/71085.html
Best regards,
florentw
Florent
