hud789
Video stream stopped when a custom IP is configured when running with gstreamer on Petalinux
I have a Video processing pipeline designed to run on ZCU106. The pipeline diagram is posted below. I have a HDMI Rx in, the format and resolution is converted through a VPSS and data are written to DDR by a frame buffer write. Then the data are read by a frame buffer read, processed by our custom IP, written back to DDR again and then displayed on DP port.  Our custom IP has a wired port to GPIO to configure the rows and columns of the video frame. The GPIO has a default setting of 1920x1080. We built boot SD card image with Petalinux and it booted well.
If we configure the VPSS output as 1920x1080 and run acquisition with gstreamer, the whole pipeline works fine. However, if we change the GOIP value to 1280x720, then configure the VPSS output as 1280x720 accordingly and run acquisition, the pipeline stop working. The stream frame rate drops to zero.
To make sure our custom IP works for 1280x720, we set the GPIO default value to 1280x720 and rebuilt, This time, when setting VPSS to 1280x720 after power on and do acquisition with gstreamer, the pipeline works. The frame rate drops to zero when we configure everything to 1080.
It seems it is configuration timing issue since it only works for the resolution of GPIO default setting when booted petalinux. FBR and FBW reset are hooked up to EMIO like TRD design. C_IP reset is hooked up to GPIO.
Anyone have any ideas?
Tags (3)
hud789
Added a user controlled reset signal to my custom IP, as well as adding register slice before and after the custom IP resolved the issue. Whenever the resolution is changed, the custom IP is reset by user application.
florentw
HI @hud789
Well. It sounds like this is an issue with your IP.
You would say start by adding an ILA after the GPIO to make sure the configured value is correct.
Then you might need to dig deeper into your ip.
Then if you want to avoid thinking about the VPSS, just create a buffer in memory that you read to (so you only use the mem to mem path)
I am not sure what else I can tell you. You need to understand why your IP is not working. So you might want to simulate it, add ILA into it etc...
Florent
hud789
Thanks Moderator.
I tested my IP on Bare metal build and it worked fine with all resolutions. And as I mentioned, It also worked on petalinux build if the resolution if set as default value of the goip, no matter what it is.
I explored the vcu_trd design document and found that the vpss and frame buffer read/write are reset while the resolution is changed. I don't see this in my design. My design is pretty same as the trd, with rest signal connected to emoi gpio. I tried to change the reset signal with
echo 380 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio380/direction
echo 0 > /sys/class/gpio/gpio380/value
But I received an error message telling me the device is busy. Seems like device driver is controlling it, but it won't toggle while setting the resolution. Any comments?
florentw
HI @hud789
Maybe try to disable the driver and control the GPIO IP from the userspace
Florent
florentw
HI @hud789
Do you have any update on this?
Florent
hud789
