What's the mean and function of mdt_tr\tv、sdt_tr\tv、vfb_tr\tv ports in the Video Format Bridge IP?
I find that there is a Video Format Bridge IP in the MIPI CSI2 RX Sub-System Block Design.
After a lot of search, I find that Xilinx doesn't provide any product document about this IP.
So I just wonder, what's the mean and function of mdt_tr\tv、sdt_tr\tv、vfb_tr\tv ports in the Video Format Bridge IP?vfb.png
回复: What's the mean and function of mdt_tr\tv、sdt_tr\tv、vfb_tr\tv ports in the Video Format Bridge IP?
Unfortunately, the IP is hidden for a reason, it is only for use inside of the MIPI CSI-2 RX Subsystem. We do not support using the IP stand alone, which is why there is no documentation.
