t-koyama
What will be the lowest level FPGA for Displayport 8Gbps speed?
What will be the lowest level FPGA for Displayport 8.1Gbps speed?
I would like to know which device can be available Displayport 8.1Gbps.
PG230 has little information but it's not enough for us.
actually , we will use XCKU15P-1 but PG230 said Ultrascale + -1i,-1e limitation is 5.4 Gbps  .
I don't know why kintex ultrascale -1 grade cover 8.1Gpbs but kintex ultrascalePlus doesn't cover it.
Could you help us ?
watari
Hi @t-koyama
Do you want to achieve HBR3 with the lowest level FPGA ?
Or, do you want to achieve ex. 8K with DSC with the lowest level FPGA ?
Best regards,
t-koyama
Dear Watari
Thanks for your reply.
Actually we want to achieve HBR3 with the lowest level FPGA.
t-koyama
Dear watari
forgot one issue
we don't need DSC function , only need line rate.
florentw
HI @t-koyama
Where did you find this information? This is from the latest PG300:
For both Ultrascale and Ultrascale+ you will need to use at least a -2 speedgrade if you want to support HBR3
Florent
t-koyama
Dir Sir
Thank you for your answer
I've understood it. it solved.
This is not question only interesting.
but I have little confuse it ,because that data sheet update at August 31st and
previous version described ,
it seems to be all Ultrascale + and Ultrascale cover 8.1Gbps,,,
Are there any problem on it ?
florentw
HI @t-koyama
I believe this table was not mentioning the speedgrade, thus was not really following the Datasheet for the device.
The new version of the doc is clearer
Florent
florentw
Hi @t-koyama
Is everything clear for you on this subject?
Florent
t-koyama
Dear sir
Sorry for reply late.
I've got your meaning, and clear all things.
Thank you very much.
aoifem
Hi @t-koyama
If this issue is resolved, could you mark the answer as 'accepted solution' so the community can find it faster?
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
