watari
Where is recipe file for V4L2 DP 1.4 Rx linux driver ?
Hi all
I found the following wiki page and I'm interesting it.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/141950977/Xilinx+V4L2+DisplayPort+1.4+RX+Subsystem+Driver#XilinxV4L2DisplayPort1.4RXSubsystemDriver-MissingFeatures/KnownIssues/LimitationsinDriver
I know how to build it by make command.
However, I'd like to build it by petalinux-build or yocto.
So, I'm looking for recipe file for it.
Best regards,
florentw
Hi @watari
What you have found on the wiki page is an early drop of the Displayport Rx driver.
The development team is in a process of pushing the driver to Xilinx git . In future they will be built as a in-tree modules so they have not exercised Yocto steps to build the modules .
By 2020.2, the modules will be built using Yocto / Petalinux flow .
Florent
watari
Hi all
I described recipe file for DP 1.4 and attached it as kernel-module-dp_git.bb.txt .
Now I don't have valid license of DP 1.4 on Vivado 2020.1. So, I couldn't make sure it.
Would you someone make sure it ?
[Note]
I request that Xilinx add tag, ex. rel-v2020.1, on dp-modules.git repository.
This repository is a little strange for me.
Best regards,
florentw
Hi @watari
Florent
watari
Hi @florentw
Thank you for your reply.
My thought is same as you mentioned.
I hope Xilinx will unveil it at 2020.2.
Best regards,
